1 - 12 of 12 Posts
I went to install my new headlights and dicovered it to be a bigger job then I expected. do I have to remove the intire grill assembly or is thier a short cut I'm not seeing?:confused:
It's BTW Not AKA!
Removing everthing on the front clip makes the job go a whole lot easier. Getting the grille out will be the easiest part of the whole job.
Ok thinking I my just return them. not worth all that but we'll see tomorow and how I feel.
thanx that got me what I wanted. If the weather cleares up in the morning I'll get it done
Banned
wow. i had the same problem.
search it on google. thats what i did. its two bolts on th aback of the whole deal you gotta take them out... you can reach them from under the hood with a long rachet extention. its like 11mm or 10mm
Discussion Starter · #10 ·
Ok i ran out of time today because of weather. I will install them next weekend and post pics. I have found you do have to remove the grill battery and coolent resivore to access all the screws. looks simple but time consuming. thanx for the help to all
Discussion Starter · #12 ·
1 - 12 of 12 Posts
