Status
Not open for further replies.
41 - 60 of 76 Posts
My 78 F-150 Lariat is a soild color ,it is listed as as a Tu tone delete on the window sticker. In addition to the race track trim it also has the lower trim along the bottom of the truck even across the tool box and the wheel well trim. I have read from a 79 Dealer book that you couldn't get the lower trim and wheel well trim with the Lariat option. I have seen a couple Lariats on ebay with this also. I sure looks factory to me. It's not listed on the window sticker though. I am waiting for my Marti report to come back and see what they say. Maybe the dealer installed it ,I don't know .
Discussion Starter #42
Tony, the wheel well trim was not put on by Ford if it had the lower racetrack trim. If you see a truck now with the wheel well trim it has been added by the owner.
so you can have a Custom XLT? That is, the freewheeling XLT package added to the Custom?
Discussion Starter #44
No. The Free Wheeling package was not an XLT package, it was a seperate package all in itself. If you ordered a Custom and put all the options on it to make it an XLT it would of been a Ranger XLT. A Free Wheeling Bronco was available in either a Custom or Ranger XLT form. Ordering a Free Wheeling Bronco did not make it an XLT.
Ok thanks.. but forgetting about the free wheeling package, I swear my friend has an "XLT Custom". It definitely isn't a ranger, but the emblem sayes XLT as well as custom.
Discussion Starter #46
That would be a 1st Dave. Check to make sure the XLT badge is not glued on, originally they used the push pins in the cowl. So lets say you have the push pins on the XLT badge the Bronco Custom emblem could have been changed at some point as well. It is hard to say but I have never heard or seen a Custom XLT made.
Ok, so it's either a "Custom" or "RangerXLT"?
Or can it be a "Custom", "XLT", or "RangerXLT"?
In the picture below from the brochure, that is a ranger xlt?
Discussion Starter #48
Correct, no Ranger or Lariat packages offered for 78/79 Bronco.You could order a Ranger only in the F-series.
You have better eyes than me but I'd bet it is a Ranger XLT.
I'll see if I can post my info when I get home.
Thanks.. so I can def see it says XLTin the truck above from the brochure, then its a Ranger.
Discussion Starter #50
Yes and no. Let's say you wanted to order an XLT but didn't want carpet, you could of ordered it with the vinyl mat with all other XLT options. The nice part about buying a Bronco back then is you didn't have to take all that was in the package like you do today.
If it says "XLT" on the side its a Ranger XLT, so you will, using ur example,... have a Ranger with no carpet.
Hey Ranger, in the brochure DaveG posted, whats up with the picture of the 4speed shifter? Why is it chrome and have a different bend to it? Also looks like a tcase boot and trim ring around it.
Discussion Starter #53
IIRC Dave a Ranger did not have the woodgrain door panels, only the XLT or a specially ordered Bronco. Either way it is a Custom or Ranger XLT.
Good question, I have never owned a 4 speed Bronco. Maybe that was one of the 1st Free Wheeling Bronco's they made for the car show's?
I never noticed the shifter image in the 78 brochure to be different. In the 79 brochure they changed the image of the transmission shifter though it looks like the same one for the transfer case.
My guess it's from a 2wd F-series.
The same picture in the brochure for the "79 Free Wheelin" Ford Trucks and the picture is listed under the Free Wheeling Styleside Pickup. The picture is also in the 1979 Ford Pickups Brochure under the caption of "4-speed overdrive"
I think it was a mistake!
Discussion Starter #57
Heres some good info on the factory push bars:
This is a factory correct push bar for the 78-79 Bronco's:
There was an early style bar like this that fit the 77 style bumper.
Mounts for a 77 model bumper:
Mounts for the 78-79 bumper:
You can see the difference in the way the top mount plate is bent. The problem comes when trying to mount the bottom bolts. 77 style on a 78-79 truck:
It just won't work. So best bet is to match up the style of the upper mounting plate, by the pics it looks like an early model, and if you plan on using it on a 78-79 forget about it.
the Overdrive Transmission only came in the 1/2 ton 2wd fords
it is basicly a car 3 speed transmission in design and shape 4 gear is added and is overdrive
the shifter comes thru what would be normally the transfer case shifter hole in a 4wd
After reading the original post it states the Custom cab could have been ordered with pretty much any option.. With that being said, could it also have been ordered with the two toned paint scheme like the XLT's? I only ask because I want to keep the Bronco looking as OE as I can and paint it a 78-79 color but love the two toned. I don't want a two toned paint job on a custom cab if they never came that way from the assembly line.
Anyone know?
Discussion Starter #60
Yes, you could order any paint option on a Custom. IIRC you do not have any of the lower race track molding on yours correct? That would mean that it originally came as a solid color and someone else applied the tu-tone.
Here is a piece of lit from the Bronco facts book. I'll scan more and maybe start a new thread including all of the Bronco facts in the book. No where in here does it state that a certain tu-tone would only be applied to a Custom or a Ranger XLT.
Use this link for a bigger pic: http://www.supermotors.net/getfile/672476/original/standard-features.jpg
Paint color options:
Bigger pic: http://www.supermotors.net/getfile/672477/original/color-options.jpg
41 - 60 of 76 Posts
Status
