1 - 13 of 13 Posts
machine gun preacher
d44 master rebuild kit:
200 plus shipping obo:
Description:
.I was going to rebuild the D44 in my bronco, but found a good deal on some already rebuilt. Its a master rebuild kit.
Includes the parts needed to change your ring and pinion, carrier and axles. Also wheel bearings and seals, see picture.
Dana 44 Front Rebuild Kit Includes:
PINION BEARING GROUP:
-Head Taper Bearing Set
-Tail Taper Bearing Set
CARRIER BEARING GROUP:
-Right Hand Taper Bearing Set
-Left Hand Taper Bearing Set
SEALANT GROUP:
-Pinion Seal
-Gasket
PINION SMALL PARTS GROUP:
-Pinion Depth Shim Set
-Pinion Pre-Load Shim Set
-Pinion Nut & Washer Set
CARRIER SMALL PARTS GROUP:
-Carrier Shim Set
-Amenities Package
KIT ALSO INCLUDES:
-(2) Outer Wheel Bearings
-(2) Inner Wheel Bearings
-(2) Outer Wheel Bearing Races
-(2) Inner Wheel Bearing Races
-(2) Hub Seals
-(2) Spindle Bearing Repair Kits
-(2) U-Joints
-(2) Inner Axle Seals
-(2) Outer Axle Slingers
it was $225 when I bought it, I'd like 175 obo + shipping
Rockwood:
48173:
Will you Ship? (Y/N) Yes, at buyer's expense:
Method of shipment (UPS, FedEx, etc) UPS:
Payment method (PayPal, check, MO, etc) paypal:
Other info:
the wheel bearings are timkin, I'll have to pull the box out to check the u-joints. The package came from JBG if that helps at all. I'm at work right now and can't just check it. :)
1996 Bronco 5.8l E40D(soon to be ZF) 4:56 and 35s
Is this for solid 44 or ttb 44? I am interested. What is the part #?
1 - 13 of 13 Posts
