121 - 140 of 266 Posts
Discussion Starter · #121 ·
I just ran a Duck-go search as you recommended (Google is da debil!). Read through 6 or 7 different forums on them. Sounds like the RTV should be fine, especially as I'm using the OEM intake and not an alum. aftermarket.
Now I'm wondering if I should drill a little drain hole in the "turkey" pan. There was a lot of "coke" oil on the underside of the intake, so something was getting around and splashing up there for awhile. Maybe a little drainage in that pan might help to keep that from happening again.
Ultra Premium Member
Google "OVERTHINK"
Reactions: BikerPepe`
Discussion Starter · #123 ·
smart-ass! guess I'd rather over than under. ;)
Discussion Starter · #124 ·
Got the intake installed this afternoon. Couldn't get the dizzy to pop loose without fear of messing it up, so I pulled the center-cap to get as much access as I could.
When I first laid the splash pan in place... again I was met with a considerable gap under the pan. Against smarter advice, I pulled it back off and got the rubber end gaskets. Sorry Joe. I'm not sure if you caught it before but as I said, these rubbers gaskets had small dowel plugs that fit into the small holes on the edge lips and a few small overhangs that wrapped the edge. There's no possibility of those rubber end gaskets sliding anywhere, under any circumstance. That considered, I just couldn't see that pan sitting tight and sealing good and proper without 'em. Being as the pan also provided the seal between the intake and the head... I just couldn't let it go. So I let my O.C.D. run with MAHLE's recommendation. I guess we'll see if I end up back here in a few months.
Got it torq'd to 3/4 of recommended ft. lbs. and I'll finish it tomorrow, after the RTV has had time to stiffen up under a little pressure. I was hoping to get onto sandblasting the oem valve covers Dad just won't get over (I'll use the aftermarket ones I painted already for the other 400, I guess) but that will have to wait another week now, till the rainy days pass and the humidity gets better.
Oh well... slowly getting there. Thanks again @cobrajoe Even though I didn't exactly take your advice on that one, I feel I did get a lot better understanding. 🍻
Tic-Toc........
:p
After every advice post @cobrajoe posts I hear one of those "not liable" claims in my head right after reading it. I believe the saying is something like... caveat emptor? Something like that.
I think a more appropriate term would be "Your mileage may vary"
That said, I'm beginning to think I should stop giving advice......
Apparently, nobody wants to listen to a crazy, old man. I feel like the old guy George in Christine that gives Arnie the keys to the car. Nobody listened to his warnings...
Discussion Starter · #128 ·
aw man. now I feel bad. not really bad... just a little. 🤪
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual hubs
and - its sorted?
finally installed everything and up and running?
Discussion Starter · #130 ·
Not quite. I'm slow as hell with some of my physical issues and I've been waiting for the temp and humidity to go down enough to sandblast and paint the old valve covers Dad insists on re-using. I'm hoping in the next few days but that's the difference between having a pole barn and a shop here in the Pacific NorthWest.
Waaah.....waaah.......waaaaah sniffle sniffle.
:p
Discussion Starter · #132 ·
Well... I'll be fair enough to admit, if I didn't have my imprisoned bro's '82 F250 for Dad to drive around, this would have been slapped back together with no "extra" care long ago.
at least you have a barn....
i have to do it either outside or in a double garage, barely allowing to open doors when another car is parked next to Bronco.
best is you have a "plan" to finish :)
Discussion Starter · #134 ·
Well buddy... over the years I've been hangin' around this site, I've worked on my rigs in nearly every less than ideal condition you could ask for. I'm not bitchin' about a pole barn but it is what it is. I'm happy to have a concrete floor and a leaking roof on a drafty barn... as I can still recall many days working in gravel driveways or doing emergency repairs in mud and snow.
I'm not in any big rush though... as I've got my '95 waiting for a lot of other planned work with parts sitting in boxes and the ol' lady's '78 still waiting for a mild resto. Between Dad, my lil' lady and myself... I'll never run out of Bronco work to do around here. I've got plans all right... a list of 'em long enough to follow me too my grave. ;)
Discussion Starter · #137 ·
Glad you found it. (y)
Project still sitting on hold. Waiting for the damn weather to clear up. I swear to God, if I hear the weatherman whine about drought conditions this year, I'll drive down and smack him upside the head. Been raining nearly every other day and humidity just won't go away. Next week is looking good... but if I had a quarter... ;)
But when you go to weatherman, do it whilst he is live on TV :)
Discussion Starter · #139 ·
Finally... she's just about ready to go back in. Now I'll get Dad's rig in the shop and take a good look around the engine bay, make sure there's nothing needs doing while I've got the space and then... who knows? Might get this bitch installed before Dad kicks the bucket.
Anybody know off-hand where to find those spark plug line guides that clip onto the oem valve covers? Checked 3 auto places today and couldn't find a set local.
I must have waited a week to upgrade the blast cabinet, wait for the right humidity (still being soggy as hell for the inland PNW this time of yr.) and finally got the spark plug heat shields blasted and painted. I didn't expect the engine enamel to last long but thought it would help buy time against corrosion. Finally went to slep 'em on... only to find out the "OEM" repro manifolds have such a large bulge on the top that the damn things won't work with 'em.
Anybody need a set of corroded, blasted and painted heat shields?
Driving Stuff Henry Built
I'm not sure if they'll fit, but Summit shows some for Ford. Search terms that helped were "Plug Wire Loom" & "Plug Wire Seperator".
