when ordering install kits for D44, i keep seeing different part numbers for 92 and older and then 93 and newer. what is the actual differences in these? i assumed it was something with the oil slingers and shims. but i never really knew and i dont see any info about it. alot of brands have different install kits for each.
i ordered a Revolution install kit 35-2033IFS-B. it came with the wrong inner pinion bearing/race. the race is 2.85" OD when 3" is what i need. the cone fit fine on the pinion and is already pressed on. ill have to remove it now to ge tthe right one on. is the difference between the years the inner pinion bearing size? when i look up the pinion bearings, it showed the same 3" size for 80-96
