I have a Dana 44HD from a F250 that I bought for my 8 lug upgrade. I have all the pieces, both steering knuckles, spindles, the ring and pinion (3.56), everything you need to rebuild this axle from my 78 Bronco to a 5 lug axle. Everything is in good shape, a new seal, maybe the bearings and this axle will be ready for a SAS. I bought this axle, took the outers off of it and installed them on my Bronco to make my front end a 8 lug. It still has the leaf springs attached, with both the front frame mount and the factory rear frame mount (cut out of the frame) still attached. $100 takes it.
Photo's of this axle are on HAVE AXLES MAKE OFFER thread. I either need to sell this or I'm scraping it this weekend.
I'm in Seaside CA, 93955 and will consider meeting somewhere nearer to your location.
what shape is the 5lug stuff in and how much for just the axles inner and outer
I'd be very interested in the front and rear spring hangers, and the ubolt plates off the leafsprings if you decide to scrap it out.
rotors, calipers, spindels, everything is good. All the parts here except for the axle housing and inner axles just came off my truck. I blew the rear axle, upgraded to a Dana 60 so put the 8 lug stuff off this axle in my Bronco. If you have questions call me at (940)231-8113. I'll answer whatever. I can part out if that gets rid of the majority of parts... Like I said, there's a good photo of it on my other posting
this axle has squared off u-bolts on top of the leafs and a round thick plate on the bottom of the axle... Is that what your looking for?
Wrenching for a Livin'
i would also be interested in the spring hangers if they become avaliable....i would need a few pics of them thou.
guess im 2nd in line....
