I am in no hurry to rebuild this but am working on getting the parts together. I am likely going with an 4340 alloy axle shaft kit with full circle clips and yukon joints with 4.88's and an ARB. Not sure where I am sourcing the shafts from yet. Recomendations? I have looked at a ton of sites so I think I just need to make up my mind. I have two other questions. First can the ball joint style axle run a high steer setup? I can only find a high steer kit for the Kingpin style axles. Also I need new spindles. I have seen them on JBG for $75 and again somewhere else (I forget) that were $200+. I want to go with the best of everything so I am wondering about the $75 JBG ones. Anyone know about the quality of those? Should I just go with Ford OEM? Is a spindle a spindle or are there good and bad ones? Other than those two things I think I should be good to go. I am going to get all new ball joints, bearings and seals along with Warn Premiums so all thats easy. I already have the new calipers, rotors and pads. New ARB with master install kit and new pinion yoke. Aside from the spindle nut socket is there any other special tool I will need? I am having a friend setup the ARB/gears at his shop. Am I missing anything? Thanks for the help and advice.
