Status
Not open for further replies.
1 - 16 of 16 Posts
Chaos is coming!!
Are they made of titanium??
I can get axle sets all day for $200. You just gotta search for them.
The front axel has wedges trackbar mount welded inplace.The rear has new diskbrakes.Call Dynatrack c howmuch they get.
No avatar required
Your price is high, about twice the going rate, but for shits and giggles I checked Dynatrac. Here it is for a complete axle, with choice or gear ratio. You can't compare apples and oranges. If your axle was complete and had 5.13's I'd offer you $1500 for it.
Good luck with the sale. Besides this is all futile since your post will no doubt be edited because you don't have enough posts to sell parts.
Here is Dynatrac's info for comparison.
Complete Dynatrac 60 axle assembly with 12 month limited warranty
Axle is set-up for an application with a drivers side offset pumpkin
Dynatrac Pro 60 Hi-pinion housing
Warn heavy-duty manual locking hubs
SD 35-spline, 1.5”, induction-hardened, alloy steel, inner axle shafts
(uses 1480 axle joint)
Upgraded disc brake assembly with a 5 on 5.5 bolt circle
Choice of ring and pinion ratio (3.54:1-5.38:1)
Open differential
Best pinion angle and wheel alignment for 4-6” lifts
D60 heavy-duty steel differential cover
1330 U-bolt style yoke (U-bolts included, Other yokes available
call for pricing)
Dynatrac Pro 60 knuckle, Pro 60 wheel hub, & Spindle package
79 Ford coil spring mounts set up to match vehicle geometry
(Other susp. work on vehicle is required.)
Inverted Tie-rod steering package (Subtract $495 to remove)
Width 70” (stock 67”-69.5”)
Assembly is finely detailed with high gloss black finish
Total $5,885.00
Discussion Starter #12
I guess I need to start buyin axels where you do.Ive never seen an HP 60 for 200 around these parts.Ill just hang on to em. No biggie.
While 2 grand might be high...if you can get the HP D60 fronts 'all day' for $200 and yr not already rich from flipping them..yr a fool, or a liar. $1000 for a jy takeout is about the going rate around here..on a good day.
Of course, D60 rears are a dime a dozen, though.
No avatar required
So I could get 12 D60 rear axles for a mere $.10? Is this a limited TV offer, if I order now will I get a ginsu knife too? :goodfinge
Bite me Steve. If I wasn't afraid of getting my chit run over by a train, I'd haul you up a load of D60s:smokin:
1 - 16 of 16 Posts
Status
