1 - 20 of 22 Posts
Bought a 92 Bronco 351W. Ripping the ECM/EFI out. I'm done messing with this damn electronic fuel injection....
Gotcha. LOL bought a 92 Bronco, had a engine compartment fire started by the booster. No "severe" damage per-say, everything is fixable but i'm not even going to attempt to graft a harness in. Harness/ECM/distrubution block is melted. I'm ripping it all out, for a 91 7.3/5spd i have in the back of the shop. Should be a straight forward swap. Figured i'd start this thread and add onto it as i progress with it.
Lol i was reading you name thinking a asian taking fuel injetion out... riggghhhhhttttt...
Btw its not a straight swap. You need a drivers side motor mount. . Not that difficult. If you need ideas look in my build thread
Edit: Oh and pending what trans you use a trans crossmember will be needed too. My zf5 was 6"+ shorter
I thought you were going Andrew James on us....
i read the title and my first though was "aw ****":histerica
the only thing is there was a recall cause the cruise cancel switchs were melting and causing fires. that may be why the fires started. id make shure the switch is up to date, dont want a fire burning down your deisel bko.:tinfoil
hurry up, im waiting :rofl:
I keep spare fuseable link upgrade kits from ford for the cruise control deactivation switch at the master. I bought it because it had the fire. I was actually waiting for SigEp or Gack to chime in about me ripping the efi out.
I have the complete truck behind the shop.
And what does being Asian have to do with ripping the efi out?
QUOTE]
they like the rest of us prolly have not the slightest issue with you swapping to deisel. now if you were going to a carb cause a fusebox melted you would prolly get some comments on that. a fire is a good excuse for a deisel swap :thumbup
Discussion Starter #11
LOL I NEVER SAID ANYTHING ABOUT A CARB. Just said i was ripping it out...
Actually carbs scare the living bajeebas out of me. Hell carbs were phased out before i was born. Ok maybe not quite that young but you get the point. Though sometimes i wish i had data stream with my A9L swapped in my 94 F350.
Satyr of the Midwest
Diesels are dirty. :goodfinge
guess you missed the 91. 7.3/5 speed part
diesels are awesome.
the smell of #2 coming from your rigs exhaust system, makes chicks hornier...
Discussion Starter #20
My damn ihpone didn't charge last night. was gonna take pics today. DigitalBill has seen the truck. Its been lurking around my complex. Finally cornered the owner and he wasn;t gonna fix it.
1 - 20 of 22 Posts
