1 - 3 of 3 Posts
PROPERTY U.S. GOVERNMENT
Good afternoon to everyone,
I’ve wired up my new AutoMeter cobalt digital water temp gauge. It looks amazing (will supply pics later) and is very accurate to the degree, but I must say the light at night is near blinding while going down the road. This motivates me to wire up the dimmer wire coming from the gauge.
I talked to a representative at AutoMeter and he said that there should be a wire that runs straight to the switch with a rheostat that cuts power when turned down and restores it when turned up, and is variable. He said if I wire the dimmer wire from the gauge into the wire connected to the switch, that it will work just as intended and I will even be able to variably dim the gauge along with the instrument cluster. There is a black wire with a white stripe down the middle that looks to be connected to the switch, pictured below:
153137
Is this the wire I need to hook the dimmer wire from the gauge up with?
Much thanks!
I have an 80, and my EVTM indicates a light blue with red stripe wire as the output wire from the headlight switch rheostat.
FWIW, the only black with stripe wire my manual shows from the headlight switch is a black with pink stripe, and it goes to the courtesy lights.
Hey JR, that ended up being the wire I was after! Made the process a whole lot quicker (after finding it haha). Mine ran to the bulb that lights up the headlights and windshield wipers icon. As I had a multimeter running to it, I was increasing and decreasing the brightness VIA the rheostat, the voltage varied from 8.93V-11 and some change. That’s how I knew it was the wire I was looking for. About to finish the wiring and I’ll post some pics of the aftermath.
Much thanks!
1 - 3 of 3 Posts
