When I first got the Bronco, the dimmer would inconsistently dim if I turned the headlight knob. One day I came out and the dash lights didn’t work. I’ve had this before, so I swapped the switch. No more dash lights with the replacement. Later in the week, I discovered my brake lights were out, but rear lights still work.
I noticed the fuse for the dash lights was out, so I replaced it. No dice. The taillights fuse is also blown.
So, I got the wiring harness and swapped it in, and so now, what I’m wondering, is there anything else I should look at before I put those fuses in to see if it blows?
This truck doesn’t have the cruise control switch (even though it has cruise control) that’s on recall and leaks. The plug for the headlight switch was falling apart but no real burn marks that I could see.
