181 - 200 of 248 Posts
Are you going to repaint the interior? I've been doing a bit of research and it looks like Monstaliner has a good product for interior use.
ate lug
88 + 96 broncos, 96 F250
Discussion Starter · #182 ·
Im gonna spray Al's Liner HNR (Heat & Noise Reducer) and their bedliner.
https://alsliner.com/
Ive already used it on the underside of the big bronco tub, so i have a rough idea how to put it down now :toothless
Afterwards ill put all the trim & the rear panels back in, just not the rubber floor.
ate lug
Discussion Starter · #184 ·
Heres the last big hole in the floor, all cut out:
Had to cut out the plate for the seatbelt spool, due to rust underneath
New pieces
...and all welded up!
This actually might be the last hole to fix :cool: Tomorrow im gonna pull it outside so i can go over the floor with wire wheels, flap discs, etc, cleaning up all the surface rust. Hopefully i dont find anything else that needs to be cut out.
ate lug
Discussion Starter · #186 ·
I have rear seat from an Early Bronco is you want to go the narrow route to make room for the spare.
Huh, thats actually an interesting idea. Let me see what i can come up with for the stock rear bench, if it doesnt look like its gonna work out good then ill def get in touch with you :thumbup
So i got the bronco outside, and cleaned up the rear floor pan. Lookin pretty good now!
Nothing left to repair in the back half. I was concerned with a couple spots up near the front seatbelts so i delved a little deeper. On the pass side, just a small hole hiding behind the seam sealer:
The d.side looks a little rougher:
After stripping the sealer away i found this:
So i guess ive still got a little more rust repair to do. I feel like the d.side is gonna suck, what with it being a seam, and in a corner, but we'll see. Hopefully tomorrow i can fix that small hole on the pass side and then move over to begin the prep work for this.
Its kinda funny; this is really the first time ive ever done any 'real' rust repair/body work to a vehicle before, and its fairly minor considering what some other members on here have had to deal with (bonsai dave, david-09 & a few others come to mind), but this is some pretty good practice for when i get back to work on the big one :toothless
No avatar required
Just let me know, it's sitting in the shed. I ever have some 4pt harnesses I was going to use in the back my '79 but never did.
Yup! Shock mounts are in the same place too. If it wasnt for the fact that you have to shorten the driveshaft by 1", it would be a 100% bolt-in job :cool:
Drop a 60 front in and make a buggy out of the 88................
At least Ford Engineering is consistent. Mine has the same holes in the same places. Just a little bit worse once you start to dig into it!
ate lug
Discussion Starter · #190 ·
Will do :thumbup
Shh, dont tell anyone, but i was talking to Eric & he said hes planning on pulling that D60 out of the front of his F350 next year........
Ha, yeah, my other trucks have rust in the same places. Some better, some worse :duh
ate lug
Discussion Starter · #191 ·
Hole patched! Its not a great job, but itll be hidden once the interior is back together.
Up front, i have to strip the sound deadener. Originally i was going to cover it, but its peeling up pretty badly so its gotta go
Masking off the interior. I have tape sticking up thru all the screw & bolt holes so i can find them later
More masking
..and done! Its sprayed with Al's Liner Heat & Noise Reducer. Hopefully this stuff works well, i guess we'll find out soon enough. They claim that a 31 mil coat is all it takes to do the job (approx 1/32"), which is what ive got down. I do have enough to do a second coat, im still debating doing it.
Its borderline too cold to spray it & leave it outside, and i couldnt climb back in with it wet, so i had to winch it back into the garage. Nice and warm in there so it should be fully cured tomorrow.
Looks like weve got some kind of storm front rolling in tomorrow, so i doubt ill get to spray the bedliner until next week.
So ive got about an hour into masking off the truck; a lot of it is that the HNR & Bed liner are so thick theyll cover over the smaller holes for the interior trim, so ive got a ton of tape-work to make sure i can find them after the liner is down. Like anything else, all the time is in the prep; it only took about 10 minutes to do the actual spraying.
ate lug
Discussion Starter · #193 ·
I just like to tinker :toothless
We got a break in the rain, so i figured id go for it and hope it didnt start again. So here we go!
Masked off and ready to go
...and second coat done!
Close up; the HNR has a texture to it.
I still have a little bit more but its getting thick, i def dont think i need a third coat. It looks good once its dry, but its no good as a top coat; it really needs something over top of it to keep it in good shape. Fortunately, next week itll be getting coated in bed liner and then i can start putting the interior back together :rockon
ate lug
Discussion Starter · #197 ·
:toothless
Yeah i think its gonna work.
Windy today, but right now the weather looks good for spraying tomorrow. Hopefully, id like to get this done, i still have more stuff to do to it!
ate lug
Discussion Starter · #199 ·
Perfect weather, so here we go!
First off, better masking. I leared the hard way on this one. The HNR and the bed liner gets sprayed with an undercoat gun due to its thickness. So overspray is a real concern. Somehow i apparently got HNR all the way up on the roof :banghead
Bought 3 kits just in case. Ended up only needing two.
Its a 3 part kit, plus black pigment. YOu add all the compnents to the large jug and then stir it up real good. Once thats done youre committed, as it begins to cure. I shot this stuff int he summer a couple years back and it set up in like 15 minutes! Today its only 35º, so i had a bit more time to work with it.
This stuff is noxious, you dont want to spray it indoors, and honestly you probably want a respirator outside too. Its also a sticky mess, so that combined with the limited working time means i didnt take any in-progress pics. So here's the finished product!
I winched it back into the garage so it can cure un-disturbed. Al's claims 24 hours to dry, but 72 hours for heavy use. Ill probably give it a full 48 hours and see how it feels, before i start putting the interior back together.
Close-up of the liner. Its still curing, so its super glossy. Hard to get a pic of, but it looks just like any other professional spray-in bed liner.
It needs to be undisturbed for a day or two, so no more updates until after Xmas.
ate lug
Discussion Starter · #200 ·
Its cured, lets get this thing back together!
Front done:
Rear going together. i replaced the tailgate/bed seal while it was apart.
Finally! The whole point of this project was to put an interior carrier in!
So, we know it doesnt clear the seat. We also know Solo Motorsports sells a kit to do this, but its super expensive!
So here's what i came up with. Move the seat brackets to the forward hole, and drill one hole in floor. Nut & bolt. You hit the same floor reinforcement as the other two, so no worries about it being strong enough. This moves the seat forward 2¼".
Perfect! Just clears :imp
The latch doesnt hit the bar now though, got to do something about that
....and spacer! It needs to be spaced off 1¼". So build one of these!
Done! It got painted before the final install.
..and finally! The interior project is finally done!!!:rockon
i also snagged a dome light off ebay for cheap
....and here's the next project, which i hope to start this afternoon :imp
