1 - 3 of 3 Posts
When driving my bronco when slowing down or going around 30 MPH i experience a terrible shake. My steering wheel is loose would that cause it. Also sometimes it feels like the entire truck is shaking and not just the front end.
Is it only when you apply the brakes, or just in the act of slowing down? If its when you apply the brakes, check for a warped rotor. If it shakes all the time or at certain speeds, check for a lumpy or unbalanced tire. If it happens only while slowing down, but not necessarily with the brakes engaged I have no idea.
Hey I had the EXACT same problem. The shake makes the truck totally scary to be in haha. and you have to come to almost a complete stop for it to stop. Any look under the front of the truck where the ttb thing connects to the cross frame and theres i think 2 bolts. i can almost guarentee theyre loose as a sob. tighten them up and go through everything else in the front to check for loose bolts. It fixed the problem for me and made it ride a hell of alot better.
Anthony
1 - 3 of 3 Posts
