1 - 20 of 117 Posts
If its trailered, id go full spool front /rear.... Their cheap... If your drving this on the street I'd go air locker up front(wish i did, but funds werent available) and detroit out back....
Need a Bumper?
I like your signature. I tend to never have enough of both though. Still running stock axles but planning to do buildup on both. I know the 44 is going to give me issues so the plan is to build the axles and eventually replace them with F/R 60's and use the existing 9in and 44 on a light weight tube buggy but for now got to work with what I've got.
Administrator
2012 Jeep JKU
still need an answer, If trail only, hell weld up the rear or spool, daily street driven I would say selectable but once again big bucks. front you could do anything you want since its only functioning when the hubs are locked.
Administrator
2012 Jeep JKU
Whats the biggest difference between the detroit and the spool. It's not a daily driver but I do like to drive it to some trails close to my house 10-15 miles max. otherwise it is trailered
a detroit unlocks when your off the pedal, a spool is constantly working, just imagine that you welded both axle shafts together and they now function as one solid length shaft, thats a spool.
Sayulita Layta!
I would only go Selectable for the front-- no matter what anybody say and no matter what the truck is used for.
The rear has more options though.
-If it is 100% trailored spool it or weld the spider gears.
-If it is your trail truck but you drive it the the trail, etc. put in the detroit.
-If the truck is a Dual Purpose rig (DD and weekend warrior), selectable in the rear as well.
I have e-lockers front and rear and I LOVE them, but the truck is also my DD.
Need a Bumper?
Discussion Starter · #12 ·
I was wondering about the e locker. herd that the silanoid (excuse my spelling) has a tendancy to go out on them. ARB's are proven but not a fan of running air lines any thoughts on a cable activated locker (i.e. OX) sounds kinda fail proof to me. I've been leaning to the detroit for the rear but spools are cheap the detroit is around $450-500 for a couple hundred xtra I can go selectable. just thinking out loud
you are going to get good at fixing the 44 if you lock it. My bronco has a 4 speed and a sterling with a detroit never had any problems, just a some noise and pulling when you are on and off the gas. My 4 door one ton has a Automatic and I cant notice the detroit at all
one thing i will say about a spool is that it is predicatable, once you learn the way it drives, it will always be locked, the same with selectable, when you lock them, they are locked, a detroit or lunchbox however can be a bit unpredictable. they will sometimes not lock when you think they will, and other times will engage a bit suddenly, i am personally goind full spool out back, open in front, and it is a dd/trail rig, if i had the money id be getting an arb
Need a Bumper?
Discussion Starter · #19 ·
Yeah Especially since I'm running on 38's. I run the truck hard but I still haven't broken an axle or U joint. I know its gonna happen though, just waiting. I'm upgrading to alloy shafts and super joints hoping to add as much beef as possible
Rest in Peace Friend...
I'm currently running 38" tires on the 78 Bronco, with a full spool in the rear Currie 9" and open front Dana44. I've broken a few front shafts and u-joints, so I got some chromoly's from Alloy USA. While it's cheaper to run a spool in the front, and unlock one hub when you need it, I thikn it's still pushing the limits of the chromoly's with 38" tires on the D44. I'm looking at installing a Detroit True-Trac in the front, since I sometimes have the need to be locked when climbing the rocks. I'll prolly get to test this set-up during the next few months. Just feel like a spool is too much strain on the shafts, and most of the locals i wheel with agree. JSM84
1 - 20 of 117 Posts
