Ok, what a terrible day....my 1978 Bronco with a 460 has been slow cranking for the last month or so, the battery WAS good, just cranked and turned over slow until it finally started, then ran just fine. So after searching the threads, I decided the starter was weak and replaced it. While I was at it, I replaced the 4 gauge starter wire to a 2 gauge starter wire. I got my starter from Advanced Auto, and slapped it in. Starterd her up, same slow crank! So, the ONLY thing I hadn't replaced was the starter relay. So back to Advanced, return the core, pick up a new relay, and grabbed a new Accel Yellow Ignition coil while I was at it. So, got everything all wired in, went to hit the start button, and....tick tick tick tick...it sounded like a wall clock second hand ticking....this wasn't good...turned off the key, still ticking....finally got the negative terminal off the battery as I started to smell the burn....Blah..wires were very hot. I have a push button start set-up, one hot wire to the S terminal on the relay....I'm ASSuming the relay IN the starter is foul, locked in, and fried the starter. But why didn't it do it with the old relay? Is the NEW relay the culprit? Either way, I guess they are BOTH going back....or do you think the cheap re-man starter is fubar?
PS, I JUST Seafoamed the engine BEFORE I smoked the starter! LOL! My ol' my...
