1 - 2 of 2 Posts
Can anyone tell me the Diff. between the radius arms from a early bronco to the 78-79 bronco's? I have a pair of both and I cant find a diff.
My 78-79 radius arms are bent from a rollover and I would like t use the early bronco ones if i can. I justwant to make sure there wont be an issue.
Thanks in advance. :chili:
I believe the difference is the spacing between the holes that hold the lower spring cup to the top of the arm. The bolts are closer together on the early Bronco parts. I remember going through this when I got a replacement arm for my '79, and I think the radius arm CAPS were the same, but the location of the bolt hole on the ARM side was different.
Hope this helps.
1 - 2 of 2 Posts
