1 - 13 of 13 Posts
My diff fluid is leaking out of the top of my vent hose on my rear 8.8. Does anybody have any idea how this is possible?
I've got a 94, XLT, 302, Auto tranny.
aka: kemicalburns
either to full or its contaminated. pull the cover off and clean it out good. then put it all back together and put gear oil an limited slip lube in if you have one and see how it goes from there
But what does mine say?
Did you have gears put in recently? I assume it's lifted? Sometimes, when you have it regeared, the guys at the shop will fill them to the required amount. However, if it's lifted, the pumpkin is at an angle that would cause it to leak. If you drain it, and then fill til you can see the level (or touch it with your finger) then there is plenty in there. ( I know, that's backwoods mechanic) If that's not the case, well kemicalburns seems to do a good job of speaking my mind for me.:thumbup
Yeah 6 inch lift and I notice it leaks mostly when I'm parked in my drive way which is at a slight angle.(hood higher than the tail)
I did recently replace the outer bearings and seals, and then I refilled the diff, but I didn't think that over filling it a little would force it out the vent hose :twak
I will drain and clean it real good as soon as time permits. I don't need to drive it everyday so that's not a biggie.
Got my dad in the hospital now so I got to go take care of his little farm for about the next 6 weeks.
:stupid
Don't worry about it.
i was havin this issue myself, drained and refilled the diff and
still did it egven with Motorcraft addative. I work for Toyota and
techs said if fluid level is low, so since my pion seal is leaking
i now check fluid regularly and it hasnt happened since, even
towing trailer. just a though. also instead of silicone, try using
F.I.P.G sold at toyota dealers and probably others, it costs
more but once it seals its sealed. it gets hard quik and needs
a good clean surface but wont leak. Good luck:beer
Discussion Starter · #9 ·
Come to think of it, the leaking did start after a wheeling run and then an hour drive home.
Discussion Starter · #11 ·
No, no water.
Water bad.
It was actually a couple of dry creek beds with lots of rocks and few ATV trails that are now just a little wider.
I just found this thread in a search, I have the same issue... stock suspension, just road driven. i'll be changing the fluid as soon as i get the chance. i plan to put in synthetic oil to help the MPG a little.
1 - 13 of 13 Posts
