Im the guy that posted a tread about a whinning noise from the rearend when i let off the gas.. alright i put the truck in nuetral and twisted the driveshaft a little it slides back and forth about a 1/8 inch and also moves up and down and all around about 1/8 of an inch in every direction.. its not loose at the u-joint its loose where the driveshaft slides into the diff, behind the u-joint.... there is also a trail of diff fluid running from where the driveshaft is loose at.. running to the bottom of the diff.. :banghead does anyone know whats wrong??
