I've got to get a new EEC. I tried replacing the capacitors on the board, but it's just too far gone for repair. So i'm trying to replace the EEC but i've only found one online for 500 bucks and theres only one 78 model bronco at the junkyard. So will i be able to get the same ECU on a different truck? The Part # is F0TF-12A650-PD and the catch code is A0C3
You can order a reman EEC from Rockauto for about $200, or get a used one from Ebay for a fraction of the price.
What transmission do you have? Sometimes EECs with different catch codes can be used provide the vehicle specs are the same.
http://www.ebay.com/itm/1989-89-FOR...Parts_Accessories&hash=item43b77e02a8&vxp=mtr
He has a 1990 with a 351. He means the only Bronco the yard had was a 78.
I was confused at first too.
yo, As pfun advised;
Rock Auto;
for example;
http://www.rockauto.com/
STANDARD MOTOR PRODUCTS Part # EM822 {#F1TZ12A650ASA} Remanufactured; Pin Terminals; Terminal Gender: Male; Number of Terminals: 60; Flashable: No; Connector Gender: Female
Trans. code E4OD; OE No. F1TF-ASA; w/ Federal Emissions $91.89 see core charge of $67.50
Alternate/OEM Part Number(s): F1TZ12A650ASA
STANDARD MOTOR PRODUCTS Warranty Information
3 years/36,000 miles. Ignition Control modules (ICM) and ProSeries wire sets- Five years/50,000 miles. Remanufactured electronic products and engine control modules - 12 month/unlimited miles. Return & rebuild parts have same warranty as new parts. Premium wire sets - Limited lifetime. T-Series parts - 12 months.
and;
F1TZ-12A650-AUA
Availability: 4 found at 1 seller
Collectors Auto Supply
(800) 414-4462
103 Eastside Oroville Rd
Oroville, Washington 98844
Part numbers with the same prefix & basic part number:
F1TZ-12A650-ABA
F1TZ-12A650-ACA
F1TZ-12A650-ADA
F1TZ-12A650-AEA
F1TZ-12A650-AFA
F1TZ-12A650-AGA
F1TZ-12A650-AJE
F1TZ-12A650-AKA
F1TZ-12A650-ALA
F1TZ-12A650-AMA
F1TZ-12A650-ANA
F1TZ-12A650-APA
F1TZ-12A650-ARA
F1TZ-12A650-ASA
F1TZ-12A650-ATA
F1TZ-12A650-AUA (Currently Viewing)
F1TZ-12A650-AWA
F1TZ-12A650-AXA
F1TZ-12A650-AYA
F1TZ-12A650-AZA
F1TZ-12A650-BAA
F1TZ-12A650-BKA
F1TZ-12A650-RFA
F1TZ-12A650-RGA
F1TZ-12A650-RJA
