1 - 12 of 12 Posts
My door dinger continuesly goes off as soon as you put the key in the ignition. I have read that the black wire with a purple strip can be cut and the dinger will go away. Is this correct i want to be sure before i start cutting things. or what can i fix to make it better thanks:popc1: :goodfinge
Engineer
You have to close the door.
First, look at the little sealed switch in the door frame.
When I bought mine, the switch seal was bad, and when I took it through the car wash for the first time, the dinger started and wouldn't stop until I removed the switch. A $15 part and one screw later, and it was all good. I'm sure you can get one for virtually nothing at the wrecker.
Former owner of Shadofax
jb77714 said:
i unplugged mine
cause i hated that too
I believe that's all I did as well. Just undid the little plunger down in the door jamb area, pulled out wired, disconnected them and taped em up. put it back together.
Dead Horse
right above the gas petal under the dash is the chime module, just umplug the connector
Explorer driving
I also hate that f'king chime. Must be one of 10, well, maybe 10, things on my truck that still works like it did when it was new.
Back in TEXAS
Is there a way to disconnect all the chimes except for the headlights? That is the one chime that I like. It saves me money every time I forget to turn my headlights off:toothless
My truck doesn't chime with the key or the headlights. I almost forgot once with the headlights. I guess mine is disconnected.
1 - 12 of 12 Posts
