1 - 4 of 4 Posts
:popc1:
ok i need to know if this can be done and if so how, i am rebuilding my 89 fsb motor, (302).. it is bored out .060 w/.010 bearings (mexicoblock so i know i am good with bore size) i have a brand new mallory dist.. and coil. but are for a "79" motor, so no ing, module.. my question is this, can i wire them both up to run off the computer?:beer :beer :beer :beer :beer :beer
Ex Navy Nuke
Nope. different base, pick up coil(stator), probably armature too. I can get you all the parts you need to rebuild your 89 dizzy and make it new again, cheap. All new motorcraft parts.
You realize that higher cylinder pressures+more spark=Much More Likely preignition right?
Most of the people on Turboford.org say you will want to run as small a gap on the spark plugs as you can get away with.
I run .033 on mine right now with 15 PSI boost and no intercooler.
1 - 4 of 4 Posts
