1 - 8 of 8 Posts
Im thinking about ditching the sway bars on the bronc,how bad is the handling? will I gain any wheel travel?
If you don't drive like Mario Andretti around turns, you'll probably barely notice they're not on there.
Sayulita Layta!
i ditched mine and have had no problems. Travel is all relative, just dont make any sudden erratic moves and you will be fine.
Cleaning the trails
Didn't have one on the back, but got rid of the front one whe I did the lift. No noticeable difference on the road
Depending on the shocks and springs you're using you might experience a big difference in ride control. and, even if you don't notice it much during normal driving, in a panic/swerve situation they make a HUGE difference.
That said, I removed both the front and rear sway bars from my truck because they inhibited wheel travel. Eventually I'd like to build a custom long-travel sway bar and play around with the settings.
1 - 8 of 8 Posts
