1 - 3 of 3 Posts
KIT INCLUDES: Dana 44 Beam Work, 1 pr Tubular DOM 1.25" Heimed Extended Radius Arms w/Pivot Boxes, 1 pr 4" coils, 1 pr Bilstein 5100 shocks, 1 pr Front Brake Lines.....$1599.....GAIN PERFORMANCE, LIFT, & WHEEL TRAVEL w/our Cut & Turned Setup..............................................................EXPERT INSTALLATION at our new location $2349 (alignment & cams extra)................................................JUST RELEASED: Bronco Coilover Conversion Kit with machined in-line clamped engine crossbar. Engine Cage is 85% welded in our fixture picking up 1-2 factory holes for alignment to bolt up and weld, Takes the guesswork out of engine cage, (this is a partially WIY kit), Set up for any 12" Stroke Coilover Shocks, KIT $950 .....EXPERT INSTALLATOIN at our new location $1650 (shocks not included & must run Cut & Turned D44s))..........................Dana 44 Beam Work still $300............1 pr Tubular DOM 1.25" Heimed Extended Radius Arms w/Pivot Boxes still $750
1 - 3 of 3 Posts
