1 - 10 of 10 Posts
if i pull straight out on my wheel studs on my right rear hub, the axle shaft slides like 1/8, 3/16" out and then stops. this aint normal is it? if not, what could it be?
It's normal. It's held in with a c-clip that rides inside the side gear. It's not coming out unless you open the rear diff, pull the retaining pin, push the axles in, and pop out the c-clips.
thats what i was hoping to hear. i remember the same thing on a few trucks i used to have .....i dont have any vibrations when driving, and the wheel doesnt shake or anything. i just wanted to make sure because i recently had the axle break in a jeep cherokee and the tire and axle shaft decided they didnt want to be on the jeep anymore and they came out. that was exciting lol
Yep, you're fine.
That little bit of play is required for when you go to pull the c-clips out... it's kinda a pain in the ass... definitely takes two people to get the axle shafts out.
Interesting. Why do you say this? I just pulled my axles by myself with no problems.
1996 Bronco 5.0/E4OD/BW1356
Well eff you guys. :goodfinge
It might have been because of the repair bearings I used (didn't need them, just saw them and the standards and liked the wider bearing surface) and the fact that they move the seals into a different position... must have been outward.
When I took them off, I just stuffed a tire against the axle shaft and that was enough to get the clips out, but putting them back on, I needed another person.
Lick my balls
That's ok, Eric, wink, we understand
:rofl::rofl::rofl::rofl::histerica:histerica:histerica:histerica:histerica:histerica:histerica:histerica:histerica:histerica
Tee hee hee, I couldn't resist, especially since I've done it myself a couple of times with no problems.
Deeeeeeeeeeeeeeeeeeeeeerrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr.
:goodfinge
That, or maybe it's something to do with the full carrier detroit I have.
1 - 10 of 10 Posts
