I’ve been prepping my bronco to bedline the interior, and currently the only thing in the way is this wire. It’s not currently plugged in, so I hope it’s not something important. Any advice on whether I can get rid of it or ways to move it out of the way (along the ceiling or something) would be appreciated.
Automotive tire Wood Hood Architecture Floor
I think it’s the seatbelt is buckled light wire…. I THINK!!!!
On '92-96 models, that is indeed the driver's seat belt wire, so I would agree that's probably what it is on yours.
The other wire bundle that splits off from it and runs over to the passenger side is the right rear speaker wiring on later years.
My seat belt connector had one of the wires clipped by a previous owner, so it did nothing regardless of whether or not the seat belt was in use. I was doing some wiring work recently and traced those two wires through the door sill, back to a main junction behind the e-brake brace. If I remember right, the clipped wire was the power signal and the other one went to a common ground. So, I figured I could clean things up by removing the clipped one at that junction and unbolt the ground one, and nothing would be seen as any different than before. No seat belt buzzers or indicator lights resulted, so I think I guessed right... If earlier years are wired the same way, you could similarly clean yours up.
Yes, it is for the "SEAT BELT" light in the dash.
Tokool4skool,
Welcome to our Big Bronco family!
As advised by MoJoJo!
Font Material property Screenshot Document Number
Organism Gesture Font Line Parallel
From 1986 EVTM - Gary's Garagemahal (the Bullnose bible) by Ford via Gary
Here's the 86 Bronco Dealer Brochure at 1983 Ford Bronco 86 Bronco Brochure Photos pictures, videos, and sounds | SuperMotors.net
1985-1986 Fuel System Adjustments by Ford via Gary
1986 Bronco Operating Guide by Ford via Gary @ 1983 Ford Bronco Manuals & Pamphlets (Scanned) picture | SuperMotors.net
1986 Owner Guide by Ford via Gary
1986 Exterior Colors by Ford via Gary
1986 Bronco Accessories Catalog by Ford via Gary. @ 1986 Ford Light Truck Accessories Brochure
1980-86 Pickup Fasteners by Ford via Gary, but mostly for front clip
1986 Bronco Rapid Specs Guide by Ford via Gary @ 1986 Ford Light Truck Accessories Brochure
1986 Color & Trim Selection Options by Ford via Gary
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf. via member BroncMom
To discuss any issues, it's better to post each seperately in Noobie section. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories that require 50 posts to buy, sell or trade due to scammers who preyed on our members too many times.
See How to add your Signature @ Bronco Forum - Full Size Ford Bronco Forum by BigBlue 94
Forum FAQs includes for example, Hot to Use Search. How To Save (Bookmark) Threads Or Posts and more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) including, "how do I get the tailgate glass to...", etc
Try to find time to Participate and vote in our current Full-Size of the Year and in the, Full-Size of the Month Contest @ Voting
Prizes are awarded to the winner; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; & a years worth of premium FSB membership.
Al
Thanks, looks like you were correct, whoever put in the aftermarket speakers had completely disconnected it from everything. It’s a little too interwoven with other wires for me to bother following it back to the source and remove completely, but I should be able to tuck it into a panel from here without worries.
