I have a 1980 bronco with 351m just replaced distributer,coil,ignition switch,and control module. now it still wont get spark.I was told maybe the peace in distibuter is bad?? need help.
Just replaced it all? as in, hasn't ran since new parts, check your firing order again, and then do it again.
Check connections, could be something simple, before you start replacing more parts $$$
You need to give us a little more info. Was it running before you started changing parts. When did it stop running?
Also, it might help us to help you if you would go to top of page, left hand corner and click on User CP, scroll down to bottom of page and fill out additional info. Make sure to tell us at least the basics, like engine, tranny, any engine mods etc. That way you will not have to type all that stuff in the next time you post something.
Kitteh Commandaar!
All that PLUS, did you check to make sure your getting 12v to the coil?
Replaced ignition switch? is it "set" correctly for the position for key on, ignition, etc.? I hated doing that, getting it right.
