Does anyone know the real differences between DOM, ERW, and Pipe? Why can't you use pipe for your roll cage? Why won't a pipe bender bend tubing?
Just some useless info..NineInches said:Does anyone know the real differences between DOM, ERW, and Pipe?
depends on diameter and wall thickness.King Andy351 said:which is strongest?
say they are the same diameter and thickness, which one is stronger?Hdpsd said:depends on diameter and wall thickness.
Isn't that called round stock? :goodfingeDustin said:solid 3" tube:goodfinge
whatever fawker :goodfingedavids78bronco said:Isn't that called round stock? :goodfinge
That's why you bend the tubing with the seam inside the bendbig pa s said:When you start bending ERW it will have a tendency to want to crack where the welds are. There are residual stresses in the material where the weld was done.
true you can work around itdavids78bronco said:That's why you bend the tubing with the seam inside the bend![]()
