I have searched and cannot seem to find a definitive thread that shows what donor vehicles and/or part numbers should be used for common part upgrades to later model Broncos. I'm not even sure if the same parts work on all FSBs. If you'll respond with what you have used or know to be valid for the following items, I'll edit this post to keep up with everything listed.
Others?
*Need more info for Sag bracket A/C compatibility and year model Broncos that use V-belt vs. Serpentine, large bolt vs. small bolt brackets also
*F350 year model compatibility?
Please assist with Bronco year compatibility for ?? entries
Part | Year FSB | Donor Vehicle(s) | Part Numbers | Notes |
Saginaw pump and bracket | ?? | 1975-1986 Econoline | Cardone - 20860 BBB - 7310125 Lares - 2237 | V-belt setup, bracket must match Bronco engine |
?? | 1987-1996 Econoline | Same as above | Serpentine setup* | |
Hydroboost | All | 1988-1997 F250-450 | Cardone - 527079 | Will need dual outlet PS pump, pedals (or modify Bronco rod pivot) |
Master Cylinder | ?? | F350 (years?)* | Required for front caliper upgrade | |
4-bolt Steering Box | All | 1999+ Super Duty | ||
3G Alternator | ||||
Front Brake Caliper | ?? | 1973-1978 Ford full-size car (Thunderbird) | F350 Master cylinder upgrade required | |
Others?
