1 - 20 of 24 Posts
OUT OF BUSINESS / M.I.A
...fall out. Or you'll pout and shout til you find out. Mine had somehow bounced off today and fell down on the intake. Couldn't quite figure out why the sudden sluggishness and crappy driveability. So I reinstalled it pointing up, ran two layers of electrical tape over the top of it and then zip-tied it to and thru one of the extra holes on the left side of the A/C bracket.
No need to comment but this may come up in someone's future search---like dumb s&#t things I should have checked for first before throwing $20's under the hood..........:smokin:
RB
Former owner of Shadofax
Once again, the SPOUT CONNECTOR that is attached by two wires to the dizzy. The one you remove for timing purposes....at least on my '87 5.0.
S'kay?..........
whatever you say. Don't think I have one on a '95 and if so it's never given me any issue (thus I still have no idea what you're talking about, although I do have an electrical harness that plugs into the distributor). Havn't even seem my distributor in several years since it's covered by the mustang boot.
Discussion Starter · #10 ·
I'm not sure what year they stopped using them...just trying to pass on some cheap info for the searchy funktion.
Or maybe I should just delete this whole thread instead?...........
my bko ate my money
hey shadow yours is on your driver side fender by your ignition module:thumbup
its a little grey plug with 2 wires comin out of it
unless you got duraspark......we got TFI so we got em his is older so its on the dizzy, mines newer so its on the fender
So this got moved along with the TFI at the time I guess? Have to take a peek later today.
My 95 has a SPOUT on the driver side fender with the EEC connector. Go look what Fireguy50 did with a weatherpack connector. He used a two pin female on the harness and a shorting male plug. When I starting loosing my SPOUT this is what I'm doing.
Sean
spOUT = spark output (black color) is an OEM molded shape 2 wire plug/device that is used to time your vehicle in most cases using a new computer type timing light which I believe just unplug/plug into it, or older style timing light in which case you need to unplug it, set up the timing light with a clip lead and long spring device end that's inserted into the plug wire and attached to the # 1 spark plug, remaining leads on + & - battery posts, with the engine already at operating temp, check timing degree against timing mark with the light, losen/rotate dissy to correct setting then tighten down dissy, re-connect spOUT = DONE.
I got an extra one from Steve83 some time ago and IIRC you can find these in the JY on certsain vehicles from the rear ABS systems but double check his album or ask him, it was only $5.00.
FireGUy50 at rjmtechnologies sells the weather pak style spOUT which are single wire for just a few dollars and these are brand new, I still have mine in the wrapping ~ lol lol
Good Luck ~
Sean
I don't think I've found mine yet. I did find a little connector with two wires into it, it's kinda taped off to the side from right from the large harness that comes up to the TFI. But this little guy seems to just have a cap on him.
Discussion Starter · #16 ·
Is that cap removable easily, with maybe a plastic lift-up finger tab on one side to keep it in place?
Here look at these that I just found on the InterGore. The pic is from a Mustang, the diagram from a F150 forum.......
it's supposed to have a cap on it. That's what completes the connection and that little "cap" is what you unplug when you're pulling codes...
Discussion Starter · #18 ·
Are you sure about that last sentence there BD? Cuz that's the first time I heard that the spout comes out during a code pull. It's not mentioned in any of my books or manuals.
And are you just refering to KOER?..........
yea that's it. and that harness is the same for my truck, with the 2 test areas. So with this deal the issue would be if that little plug somehow came out so it can no longer complete the connection? I can't see water bothering it much.
Edit: actually I'll look at it again, but that diagram is exactly what it looks like, NOT that pic I don't believe. It's just a small little connector with like a little square plug/cap at the end, just like in the diagram.
Discussion Starter · #20 ·
Just for drill, have you ever set the timing on your truck before? By yourself? Cuz I'm pretty damn sure they have to come out before you set your BASE TIMING......
1 - 20 of 24 Posts
