1 - 8 of 8 Posts
Have a 89 bronco and the driver door lock stickers. To unlock it I have to lock the door then unlock it with the key. If the door opens slowly sometimes it catches halfway opened and I have to lock it and unlock it again.
Also it does not unlock with the door lock switch.
I am assuming it’s something with the rods but no idea. The previous owner told me someone tried to break into it about a week before I bought it.
Yo Chapys,
The early lock motors are prone to water intrusion; both in the motor itself, and in the spiral mechanism, causing poor performance, high current draw, & eventual failure. They were used in F-series/Bronco doors until 91.
164193
164194
164195
Have you actually pulled the owner and checked the rods? If it's power locks the actuator could also be going bad
I have the door panel off. Not really sure what I’m looking for in the rods is my issue.
I assume the actuator will need to be replaced but the manual part of the rods is where I’m confused. Should I order new rods?
It might help to remove the other door panel so you can watch the rods and actuator do their thing when you lock/unlock the door? It may help to see what's not happening on the other door?
This^^^^^^^
But... Given your list of symptoms with intermittent, inconsistent and seemingly under powered to put the rods thru a full cycle, I think I'd be looking more at the things that drive the mechanicals. Worn wires pushing less current, bad or corroded connections tired motor or actuator, tired springs, gears, etc... Maybe this will help
I think I want to start with the basic make it work with a key. I can skip the electronics as that removes a lot of steps and just make the mechanical work. If the mechanical is not work electronics will not help
1 - 8 of 8 Posts
