1 - 8 of 8 Posts
Just getting around to installing my door seals, It‘s been some time since I removed them.
Question is, is there a place where to start and stop, I was thinking around the top door hinge.
Any input would be appreciated
Thanks
Jim
If you can Jedi post some pics. I have to do mine and want to know too....
Do yourself a favor and if you are installing new door seal, rough up the channel on the door seal that fits over body with some sandpaper (120 grit works) first. This helps the rubber cement bond to the seal and not peel off half way through the job.
1987 Ford Bronco, beefed up 351w, JBG HD rear springs, JBG 4” coil, 10.25 rear posi, Dana 44 posi
On my 87 I cut mine at the bottom middle and I don’t even notice it.
Discussion Starter · #8 ·
Thanks a lot for all the response, it’s nice to be able to pull on all the forums knowledge
Jim
1 - 8 of 8 Posts
