1 - 10 of 10 Posts
Hey guys yesterday I put on the rear part of my lift and looking at the drive shaft it has a good amount comming out from the transfer case. Is this ok?
Blocks
(plan on getting rid of them when money allows)
I would say you need a longer shaft.
and those double stacked blocks are really a bad idea.
MARBLE GARGLER!
I agree, If you took the rear seal out you would see that there is alot less spline contact than you think.
do they make a driveshaft spacers that would work?
Thats a new one. Take the old block out, it will help a bit. How much lift is on the back? If it's only that block the rear shaft should work fine for a while. When (not if) it starts to fail just get a custom made one from ericautopart. He makes some nice stuff at a good price.
Hey guys any way I could get another shaft out of another truck to bolt up? I took the blocks out but need to get the back a little higher. Or could i make like a .5" spacer to go in the back of the shaft?
Thanks
Gotta, another thing, left the blocks on while i wait on something else to come in to get the height. I have a small vibration on it while running it around the neighborhood. We did the measurements and I have at the least 3inches of spline sleeved in. The yoke shaft piece is only 5 inches long in total. We are gonna try and do a rough alignment tomorrow and see if that works.
Thanks,
Oh yeh it is bouncy as crap going over a small bump at like 20 mph. Its got $ rough country shocks on it too.
Thanks again
One other thing its a long bed regular cab f150
I could be wrong, but from the pic it looks to me that you have the block on backwards ( with the taller part to the front).
That would be making a vibration due to the U-joint angle being off.
with an F150 without a CV driveshaft you don't want a tapered block in there anyways since it will put the angles off. If I were you, and you just have to run blocks, I'd correct the angle problem and have a CV shaft made for it that is 1" longer.
Alright thanks, I will check to see if they are tapered. And a shop in town told me to extend my existing drive shaft it would only cost $95 plus material cost.
1 - 10 of 10 Posts
