1 - 20 of 34 Posts
Josh here with a noobie question
My driver's seat in my 89 Full Size Bronco broke and I wanted to pull a seat from a junk yard with an arm rest what years and makes should I look for that will match? Thanks ya'll!
91 bronco xlt OJ edition. 5.8 auto
i think any ford truck or suv in that year genre will fit as a r/r minus any electrical bs
The link below has a lot of good info in it. Scroll down to the Interior section. There is a lot of seat threads.....
Reactions: 300inline6
If you can live without the arm rests and want comfort get a set out of an older mustang , that’s what I have and absolutely love long rides now..... even with one ton rear springs.
Reactions: BigBlue 94
Honestly I always liked the 92-96 high back seats, moreso the 40/20/40 if you can find a set as the jump seat being used strictly as armrests is a lot nicer, even moreso as a bonus for the extra seating if you add in the center belt. If you are concerned with color matching and want to give them a shot, 92-93 for blue, red, and gray, 92-96 for the brown.
umm a 87-91 bronco or truck is direct swap and perfectly matches. i replaced mine from a same year bronco cost me 60 bucks for both fronts. how is it broke? pretty easy seats to fix also.
This is the first thread over in the tech subforum right now.
Sit down for a few hours and enjoy.
Addicted to Junk
Any seat from any fullsize bronco or supercab pickup will bolt in. Regular cab and crew cab seats are a bit different in how they mount, and have no provisions for rear seat entry.
Most any mustang seat can be made to work. Or any seat from a coupe, where they flip up for rear seat access. I'm about to put some 03 mustang seats in my 85.
Yo 300inline6,
Consider 2012 or other year F150 Heated Power Bucket Seat Swap w/ Wiring Diagrams @ Power seat swap
Installation (04 Dodge Pick Up) in an 88
Source: by BUSTERBRONCO at FSB
Installation (Corbeau) in a 90 @ 1990 Ford Bronco seat swap pictures, videos, and sounds | SuperMotors.net
Excerpt; "four bolts hold it down, the hard part is the angle on the front. I needed and extension bc I could not get enough movement in my ratchet. Otherwise, piece of cake...
..here is where those bolts go through the floor pan
155092
155093
Source: by rugerp89ipsc (mean green)
I installed heated air ride seats in my 96 Bronco
@ Bronco seat questions
by gos
The mounting bracket
The
Yeah which one between the 87-91 have a cold down arm rest....?
I have welded one of the mounting brackets but it keeps breaking.
1978 Bronco Ranger XLT, 400/C6 92 K documented miles &1994 Bronco,XLT 85K original miles
Lol.... voice to text....
Addicted to Junk
Ahem....
Not all had the captain's chairs, but any from 80-96 (97 f250HD and f350) broncos and supercab pickups will work.
ahem.... again....
Ahem....
Any seat will fit if you got a welder a cutting tool and or a sledge hammer!
I have seen some pretty weird seat cross overs, like my neighbor who has 2.5 bolts holding Honda seats in his Neon ! Hope he don’t wreck!!
1980; 347 stroker; Holley Sniper EFI
Can you post a picture?? Very curious
I can get you some tomorrow it’s at my shop with a partially busted t-Case. I’ll include the underside as well. The mustang they came out of was about the same year give or take 6-7 and I spited it rear ended with a buddy needing a donor car for a cobra kit, my finders fee was any parts I wanted that he didn’t need.
Reactions: ianmurphy
Addicted to Junk
I just put a 03 mustang seat in my 85 bronco yesterday.
Check out the last post in my build thread
1985 All-Purpose Build
The holes were already there, I just had to drill em bigger and tap two, then the front two to match. Of course idk if the 89 has the same seat mount pattern.
BB94, why do you still use SuperMotors for picture hosting?
FSB's new software makes picture hosting really easy and easier to view.
Addicted to Junk
Because I trust them to not lose my stuff. I'm also on a mobile phone, so anything I dont upload there gets lost when I get a new phone. For random pics, I do use the attachment feature quite often. Plus I have 14 years of pics over there.
Reactions: CZ Eddie
1 - 20 of 34 Posts
