1 - 15 of 15 Posts
I have a shudder in the drivetrain when i am cruising and then accelerate or let off the gas. It dosent happen all the time. Just every so often. Is it the OD. or mabye a U-joint? Feels like it might be from the rear end.
Sounds like the drive shaft is off balance...same thing happened to my '92 for a few days untill it finally came apart at the cv head, and banged up the muffler and undercarriage. Check that first.
Check your ujoints. I'll bet there bad. How many miles on them.
Or the pinion nut, thats a common one too.
From what I was just told last week from my gear guy, Ford always used fine thread on the pinion and they rairly get loose. I too have heard many times that they do but he's talking with 20 + years experience and has never seen one. Now a Chebby on the other hand.
It's worth checking though.
Ok, tell him to come here and look at the 88 Bronco in my garage if he wants to see a loose pinion flange on a Ford. It seems like it is mostly the 4 wheel drive vehicles that have that problem, so maybe he does not see many of those?
:brownbag
Thats Funny, he must have not seen to many Broncos in 20+ years. Mine had 168,000 miles when i bought it and it is an 86 and i have to tighten my pinion nut about a full turn and a bit. Seems like alot but that was a few months ago and so far so good. :toothless
Same deal with my 1996. I only have about 70K miles and I got at least a full turn of tightening. The flange was loose enough to rattle it by hand. Definitly worth checking, it only takes a couple mins.
Got the same problem vinman, mine does it when you go from 3-4 or 4-3 gear. Seems worse under load, towing, etc. Wondering if it may be something with the lockup. Drivetrain is all original still, 140 000km
Former owner of Shadofax
RobertF said:
Where is this pinion nut? Sounds like something I should check...
Get under your truck, look at the rear driveshaft, follow it all the way down to the rear axle. You will see a large nut inside the union of the driveshaft to the rear axle flange. that be the pinion nut.
tired of your sh!t
mine did it too.
1 - 15 of 15 Posts
