1 - 4 of 4 Posts
i have a 93 and i know there is some threads about this but i just fixed my passenger window moter and it works like a charm but when i put the window down it torks and gets stuck but it will still go back up and it starts to tork about 4 or 5 inches from the bottem and will not go down all the way unless you hold it from torking and i can not figur out what it is. what the hell can i do to fix it.
thanks for eny imput
Zombie Hunter
your window brackets are broked.
Pull the door panel off, and put the window down half way. You should see a bracket on the right hand side and the left hand side that holds the glass.
Some Silicon SPRAY (not grease) in the tracks will help the window travel better too.
:stupid It's most likely broke, but it could be missing a screw, I have a mustang that window does that and I took that door panel off and the screws were missing now it works fine...
i will go and do that now and try the silicone spray and see if enything is broken.
1 - 4 of 4 Posts
