press ALT+F4
I would also recommend a square tube spacer between the bottom of the frame and the lower edge of the coil bucket. Weld it, bolt it, whatever, but it will need the support.
or.....you could get them from a 2wd. they are around 2-3" shorter than 4x4s. plus, you get dual shock mounts, but they are the top stud type. hope that helps. i think its a little safer than spacing the stock 4x4 buckets down!
I've seen people cut 3" out of the coil buckets and re weld it back together to eliminate adding a spacer between the frame and coil bucket.
