Biggest question is; why? You can buy 130 amp 160 amp & 200 amp 3G alternators. Any of which is adequate. NEXT.
Yet again making stuff more difficult than it need to be. KISS.
WHY?!?! Maybe because i want to??? :twak
And since i have a 160 3g already ... that kills the "v" belt when it ramps up to charge the batteries in my truck (since you have a 79, you can see how far the belt has to go to get from the crank pully to the alt, it is never tight enough, without being overtight)...... also i have the possiblity of quite a draw when doing a vehicle recovery... lightbar (fed sig vision bar - draws around 45 amps), and a 10k winch (or the 8k on the rear) and i already have 3 batteries in the truck, to help lessen the sudden draw. Also maybe (since i was in the avaition game) i believe in redunant systems... And if i can do it with not alot of work... so much the better.
Fireguy gave me the answer i needed :beer . I don't want/need to spend alot on a dual regulator sooooo.. what i will do is just make a second system to power the accessories and one to run the stock demands of the truck.
And if i wanted to KISS it, i guess i should have just left it stock, i mean why should anyone change anything?? it is easiest to just leave things as they are.....ford engineers have already worked out the "best" truck that will work for everyone.
