i was out wheelin last w/e and put a hole in my front tank, was pretty much empty, so i've been using my back tank all this week, everything was fine, well, i just put 10 bucks in the rear tank, and the front one starting leakin...it's an 84, there's no return line, so it cant be getting pumped back into the wrong tank...what the hell
Ex Navy Nuke
I know it's a different year but my dad's 94 pumps into the front tank when the rear is on also. Not sure exactly how your setup works but apparently the valve that switches between tanks isn't switching all the way and is allowing some fuel from the rear tank to go into the front tank as well as up to the engine.
i didnt install the tanks, everything is factory....and worked fine up until today...
front tank was definitly empty, didnt leak at all until today...
everything was workin fine, was just using the back tank cause of the leak in the front, then when i put gas in it today, it started coming out the front, our work truck does that...pumps gas into the other tank...i know they do that, but i guess mine just had to start sometime...
