1 - 20 of 85 Posts
Got my Bronco registered today so it’s time to start the thread. In January I picked up a 1 owner 02 4x4 Tahoe that needed a new brake caliper and a tune up from a friend’s family friend for an amazing deal of $1k. After getting it home and fixed, new wipers, air filter, and oil change, I was about $1300 in it. Listed it on Craigslist for sale or trade for a Bronco. Fella messaged me in the next few days wanting to trade for an 89 Bronco. So after driving an hour to check it out I went from this (only pic I have of the Tahoe)
To this
1989 Eddie Bauer
Fresh black paint
5.0/AOD
4” pro comp lift
4.56 Yukon gears/LS in rear
35x12.5x15 General Grabber AT2
15x10 MT black steelies
Bumpers
Winch
Fender flares
It needed lockouts as it had the old plastic ford ones that were toast. Due to that the PO has never locked it in 4wd and couldn’t tell me for sure if the front gears were matched to the rear 4.56s. I assumed they weren’t and was correct. Anyways, I had a set of warm premium lockouts that I put in and 4wd started rippin.
Brought it home on a Saturday and checked it out, then took it on a trail ride at the lake Sunday. It did great and had no issues, even with the mismatched gears(I only locked it in when necessary to cross mud). Here we are at the lake
Gave it a bath, took the fender flares off and started ordering parts and tinkering. Yukon 4.56 front gears, husky floor mats, Window seals, thermostat, upper radiator hose, coolant flush, fixed rear window dash switch and tightened the interior up with new clips and missing screws. Fixed a no start on cold start and fuel sending into problem. Daily drove it for 2.5 and owned it for about 4. This is Bronco number 3 and I’m happy to have this one.
Without fender flares
The plan for this truck is to go back to the original Eddie Bauer paint scheme and finish out the interior as its missing a few things like headliner, tilt steering column and cruise control wheel, some of the interior top and headliner trim, and the original EB driver seat. This truck will continue to be modded, driven, and wheeled. I live near a big lake in North MS and with my rigs and the roommates we get a lot of calls to recover stuck people and college kids (Ole Miss). This is one of the jobs I will be building this truck for. The other will be cruising around Oxford and going to Cruisin the Coast, Super bronco celebration, and whatnot.
With a direction in mind and being on Craigslist lat at night, I found a clean looking 1990 ED bronco roller chassis about 4 hours away. A few emails the next day and it was mine. It arrived on Sunday and boy am I happy. I will be able to finish my interior completely and anything else I could want. This thing also has rear lift springs instead of blocks, a tan top, tire carrier, and aluminum wheels. Can’t wait to start swapping parts on them this weekend.
So far we’re up to date. I’ll keep y’all posted as the build progresses.
Swapped the black headlights and grill for chrome today. I like how it turned out
Headed out to the parts truck in the morning to swap some more parts over.
Horn isn’t working, so while I had the driver headlight out I tested the horns. Both worked. I need to dig deeper into that.
Very nice Bronco, it looks much better without the fender flares. I’m also really liking the stance with the 4” lift and 35” tires
Thanks PowerB, I really appreciate it.
Exhausting work this weekend. I swapped the front and rear seats, rear trim panels, carpet, chrome fender trim, and rear speakers from the 90 to the 89.
I had planned to swap the tan top as well, but wind at the marina was rippin today and I only had one extra set of hands. The carpet and seats still needs to be cleaned l, but they have much more life than the ones I swapped and now I have full Eddie B interior in the 89. I didn’t swap the front carpet as the carpet in the 90 was faded. The only problem with the carpet in the 89 is a bald spot on the center hump, but I plan to build a center console to go over that area for some more front storage.
Discussion Starter #12
Long day at work yesterday, but I was able to squeeze in some time at the end of the day. I had one of my dock hands help me swap tops and then I swapped in the new/used air box, intake tubes, cold air duct and added a new air filter. Old one was BAD! Today I’ll be ordering a backup light switch to hopefully fix my reverse lights staying on in all gears but park. Hopefully find time to replace the rear window top seal today as well. Enjoy.
Discussion Starter #14
Yesterday I popped the top off for St. Patrick’s day and eased into town to watch some SEC baseball. After that we rode out to the lake to check the water level.
I’m starting to think about swapping a solid d44 into the front. I’m not sure which route I want to go yet, but need to figure it out before I rebuild the ttb and have the new front diff setup. Decisions decisions...
Almost forgot, I installed my new tag yesterday as well. Still unsure how this was available
When I think of an antique car the Model T or a Stanley Steamer comes to mind. Not an 80's Bronco. lol
I have a personalized plate planned out for my 78, but I just haven't ever gotten around to ordering it.
BTW, I just looked up "Bronco" in my state's DMV online and someone here already has it. Lucky you, sir.
Discussion Starter #17
Today I got around to dropping the fuel tank. An old repair from the PO let loose and she started dripping. The tank dropped out fairly easily. One man, a jack, and about 45 minutes. Ordered a new one from rockauto, it should be here Monday. Bout to head back out and install the drivers side step.
Discussion Starter #20
Do you still have the black grille pieces?
Yes I do. Was thinking of using it for wall art in the shop. 3 of the 4 mounting clips are broken off which is one of the reasons I changed it other than CHROME haha. Are you needing one? I know where another nice chrome one is in the u-pull it I could snag for you next trip out. It could be painted like the black one is
1 - 20 of 85 Posts
