1 - 13 of 13 Posts
Too many broncos!
I have some engine upgrades in my future, so decided that it would be a good idea to Dyno the truck now and see how the upgrades workout. Unfortunately i didn't do this before my exhaust upgrade (Y-pipe) back.. but it should be interesting none-the-less.
Now to be upfront, iam not an experienced gear head and don't have allot of knowledge in this area, so i'm learning as I go. I'm interested in your opinions and ideas, however I'm pretty set on some aFR-165 heads and maybe some headers.. again i replaced everything Y-pipe back
I know the basics of the Dyno results and talked to the tech as we worked through it and did the runs. For being almost a stock 302 with 95K it seems to be doing ok.
My current config:
engine stock, y pipe 3" through cat, reducer to 2.5" to muffler out.
35" tires, 4.56 gears
The stock original config for a bronco that i found was:
1994 5.0 (302 ci) - 185 hp @ 3800 rpm - 270 ft/lb @ 2400 rpm
The first chart was through all the shift points, overdrive off.
the 2nd and 3rd charts are from 2nd gear runs
anyway here are the results.
Urban Assault Bronco
not too shabby man, not too shabby, for what you have done, i would be happy
pretty sweet numbers. my stock 5.8 made 170/258
That's awesome, most people don't ever dyno a Bronco so good info.
The HP is very high considering 185HP was crank before drivetrain loss and your still making more then that at the rear wheels.
Was it a dynojet or some other brand dyno?
Too many broncos!
I believe it was a DYNOmite dyno setup..
Landshark99, what's the latest news on the truck? I have to get my Bronco on the dyno for some "before and after" numbers.
Looks like the dyno is STD correction instead of SAE. That likely adds about 15-20 peak Hp to his numbers. But good numbers none the less especially with big tires.
Too many broncos!
Well for the time being I have decided to leave the engine as is as I do have low miles and It's running really well. In addition I just regeard and honestly I couldn't be happier with the lower gears - went from 4.56 to 4.88 - , the Bronco really pulls up these mountains now. Also I have an SAS in the works so that been taking up most of my attention. But honestly I have decided to enjoy the truck and run it as is for a while as I have done allot to it in the last 2 years.
I have most of the parts to build up the engine, but honestly I'm not ready to tear down it down.. I will probably buy a 302 roller block and build that up separately and then do a swap. I haven't ruled out a 351 either :)
In any case I will let it run for a while and enjoy it!
Yup the technician did say something along those lines. But I was impressed with the number none the less.
OP, good job, I need to dyno mine to see what it can do. What I would suggest is for you to record the temp and base timing if you haven't done so. If you make any other changes, you can use this information as a reference. If you ever start dyno'ing with a eec modifier, you should data log your session. It would be very interesting
I highly doubt it would be that big of a difference, your only talking 2-3% difference between Standard & SAE. So at worst his peak 198hp could be 4hp off.
Your right! I keep thinking in terms of 500-600 rwhp mustangs. You can pick up quite a few hp by increasing base timing until it causes detonation then back it off a couple degrees. You would need to run 93 octane though. Don't be surprised if you re-dyno the numbers could be off quite a bit from the last dyno run. I dyno'd 557rwhp then a week later it dyno'd 574rwhp at a different shop on the same brand dyno with no changes.
Good numbers on your bronco.
1 - 13 of 13 Posts
