1 - 10 of 10 Posts
I did some searching and I found Stangmata's guide to problem solving for the tranny issues in the E40D. It said the hard shift between 1-2 is normal, my question is- is it normal for the tranny to make the 1-2 @3,000 rpm's? No matter what you do, it only shifts at 3,000 rpm's. All other gears shift fine.
What do you guys think?
Thanks-
Aaron
VSS or transmission nuetral sensor
What is the nuetral sensor? the neutral safety switch? and how does that affect the shifting- forgive my ignorance, I know nothing about these trannies.
I sent you pm to, I have a few questions about your SAS if you have time to take a call.
Thanks-
Aaron
Mine does a similar thing
Goes up to 3k then shifts really hard at about 22mph. Does the same (but softer) at 40mph. All the higher gears seem to shift fine.
House of Windsor 4ever!
The VSS and the trans range sensor are very important for proper solenoid operation, as well as TP sensor position.
yo,
a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
Look Codes up in my broncolinks.com site using the new Search function if in a hurry.
And Post em here according to
KOEO
KOER
is Amber ABS light on all the time?
same for CEL
and Transmission Control Indicator Light (TCIL) (OD on/off) Switch/ LED
Late 1-2 Upshift; "...Accumulator Body Problems; The small valve indicated in the picture above will wear the hole causing the small valve to stick partially open. When the valve would stick, it caused a late 1-2 upshift, you actually had to let up on the throttle for it to shift, then all of the other shifts were perfect. We spent hours checking the TPS Sensor, PCM..."
Source: by specialtytrans.com
DTC 617 - 1-2 shift error. "...IF this code persists and you have noticed shift problems while driving, its going to be a shift servo inside the E4OD tha has failed. (Computer needs to control when the tranny is shifting)..."
Source: by greystreak92
DTC 634; "...Hard 1-2 shift after she warms up...1-2 accumulator problem. Also the line modulator valve can cause intermittent harsh shifts, but generally it would happen on more than one gear change..."
Source: by Baumann Electronic Controls, LLC becontrols.com
DTC 91 & 92 in E4OD; "...1-2 Shift solenoid circuit failure; 93 Coast clutch solenoid circuit failure(e4od), 94 Converter clutch solenoid circuit failure, 99 Electronic pressure control circuit failure, and another with two descriptions. 56 TOT reads & minus 40deg. F or circuit open and 56 Vaf or MAF circuit amove maxium voltage; I'd try pulling & cleaning the shift solenoid pack connector, and then inspect the lines from the PCM to that connector for shorts and opens. All of those codes are pointing to a problem with the connections to the solenoid pack, in the harness, or in the solenoid pack itself. I wouldn't keep driving it like you are, though. The 'default' gear is 4th, so you're creating a lot of heat trying to get going..."
Source: by SigEpBlue (Steve) at FSB
This book goes for $35.00; dnload & save
E4OD Description & Operation, Identification Tag, Parts Break-Out Diagram w/Nomenclature, Seals, Rings & Gaskets Locator, MLPS/Transmission Range (TR) Sensor & Lamp Operation, Transmission Shift Patterns, Main Components & Functions, Electronic Control System, Diagnosis & Testing, In-Vehicle Service, R&R, Cleaning & Inspection, Specifications, & Special Service Tools/Equipment; "...Covers assembly, dis-assembly, diagnosis, troubleshooting, and electronic controls & operation..."
Source: by Automatic Transmission Service Group (ATSG) via akpp.in.ua @ http://akpp.in.ua/files/program/FORD/E4OD.pdf
same for this book:
E4OD Update Handbook; "...covers engineering changes that have occured from 1989 to 1995, parts affected by the change, interchangability & part numbers. Includes: Valve body and checkball changes thru 1996; 1989-1995 valve body checkball location; 1996 valve body checkball locations; early 1989 case checkball locations; late 1989 case checkball locations; 1990-1995 case checkball locations; 1996 case checkball locations; spacer plates and identification; main valve body differences and identification; lower valve body differences and identification; case differences and identification; output shaft changes; overdrive section failure; 4th clutch snap ring change; low roller clutch inner race change; cooler line fitting changes; low roller clutch assembly change; overdrive sprag changes; ball bearing center support change; overdrive carrier and input shaft change; cast iron overdrive carrier; direct clutch housing change; solenoid pack change for 1995 models; front pump change for 1995 models; intermediate servo piston change; sun gear differences; 1989-1995 valve body; 1996 valve body (exploded view); new design pump cover and stator shaft (blocked cooler); reverse clutch lip seals for 1996; larger design low roller clutch change; new design forward ring gear hub and planetary; ew design overdrive clutch piston and housing; cooler by-pass valve added to some 1997 models; lube orifice cup plug added to 1997 models; new design front pump for 1997-1998 models; new design 6 pinion forward and rear planetary arriers; new design sun shell; ntermediate diode freewheel failure; increased overdrive clutch capacity..."
Source: by Automatic Transmission Service Group (ATSG) via akpp.in.ua @ http://akpp.in.ua/files/program/FORD/E4OD-HB.pdf
Aaron, Forgot to mention soon in your profile, include your year, engine, trans, Xfer case & locking hub type (auto or manual) and any major mods such as body or suspension lift, etc. or in any question post. You'll get more accurate replies
Thanks for the info Miesk5. The bronco I bought is still in florida, I'll have it in a week or so. My avatar pic is what I bought anyway. I'll post more pics and info once I get it and post the progress of the build I plan on doing- the SAS, updating the interior-front seats are shot, 6" lift, roll cage for Silver Lake Sand Dunes, rims and 35" tires. Its basically going to be just a summer cruizer- the body and under carraige are in excellent condition-rust free so I want to keep it out of the MI salt.
The motor runs great even though it has a ton of miles on it but I need to see if I can figure out what is going on with the 1-2 shift- I am planning on running the stock combo for awhile so I want to try the cheap fixes first then do a big block and C6 swap later down the road.
yo Aaron,
ok, gl and post the build pics..always good to see more info and builds here.
Crusher Mike
Thanks-
Aaron
yes the nuetral safety switch its odd to think it would have an effect but it does. I had the same problem when I was running 35s with stock gears when I put the 4.88 gear set in and changed the the speedo gear it went away.
1 - 10 of 10 Posts
