It has been almost a day. 36 views and no replies. Any suggestions or does anyone have any magical mystical spells I could cast?
Diagnostic Trouble Code (DTC) 634 indicate the Transmission Range (TR) sensor is out of Self-Test range when the gear selector is in "PARK".So far I've been unable to diagnose the problem with my tranny. I keep getting a code 654 MLP not in park, and 634 volltage out of self test range. Now I know the normal questions are coming. The Bronco is a 91 EB, 302, push button 4wd. I keep getting hard shifts through all gears only on upshifts. I've checked ground at MLP. Checked voltage also. Resistance through all gears is correct. TPS is correct also. Checked resistance of all harness wires from ECU to all sensors and also to solenoid pack at tranny. Does anyone have any idea what the issue could be. I'm not saying firm like shift kit. I'm talking rear-end collision rough. I have installed a new MLP, TPS, solenoid pack, DPFE, speed sensor, ecu. I have checked speed ring in diff. Any mechanics or experts have any a clue? Thanks.
Transmission range sensor.Well I have already checked and added grounds. Checked linkage. MLP match lines are lined up on sensor in neutral. Truck starts in park and also in neutral. Reverse lights come on when in reverse. I'm going to try another ecu tomm. Good thing is I've been selling parts for 12 years. No shortage of parts for me to try. The check engine light goes on and off while driving. I've been having this battle on my hands for about 7 months now. I'm really surprised to not have lost my transfer case by now. What is a TR sensor?
im pretty sure theres just some sensors and the solenoid pack, and the governer. you could try testing the pcm, or you could replace the anti-knock sensor to see if that would help.Also known as MLP and NSS correct? I have tested voltage in and ohmed to ground and also resistance in all gears. All are way within specified perimeters. The only other problem I've ever had is a lunge of sorts at startup and a stall when it hammers into reverse at times. Maybe once or twice. I have tested every sensor on the truck and check all that I can know to check. Is there anything in the design that a knock sensor would cause a short of sorts? That's the only sensor that I haven't replaced on the truck. Its line pressure I know but I can't figure what's telling the computer to go into safe mode. Is there anything more in the trans that is electronic other than the solenoid pack?
glad to help good luck.Thanks very much for the response. I will update tomm when I try the ecu. If anyone has any other suggestions feel free to let them fly.
where did you get the MLSP from autozone?I'm no tranny expert, swapping the MLPS has been the extent of my trans work on this truck. The codes pointed to it, & I changed it without testing it. :brownbag It did resolve the problem though.
Have you seen stangmata"s E4OD Diagnosis Thread?
Regarding codes 634 & 654 he says "This was caused by either a faulty TOT (Transmission Over Temperature) sensor, a bad connector or harness, or the transmission was overheated." I don't know why, since that doesn't seem match the description for those codes. You might post up in his thread or PM him & ask.
thePUNISHER also seems to know E4ODs. Here's one of his threads with his contact info: 89-96 E4OD products from Paul's ClutchBoxes
Diagnostic Trouble Code (DTC) 634 indicate the Transmission Range (TR) sensor is out of Self-Test range when the gear selector is in "PARK".I'm no tranny expert, swapping the MLPS has been the extent of my trans work on this truck. The codes pointed to it, & I changed it without testing it. :brownbag It did resolve the problem though.
Click on pic to enlarge it.I manage Carquest in Maryville. Picked up all my parts from there. Swapped out MLP's twice. Changed the plug ont the first. Rechecked all the locations on all wires when I done the second. Where is the trans temp sensor? I've read the article. Just no one has went to detail on where it is. There is no way the mlp is bad. Is the solenoid pack in the tranny designed to apply full line pressure when slippage is detected? My tranny doesn't slip at all. Its not like I've never worked on cars. I've just exhausted all my options.
I usually buy those parts at the local NAPA, ever since my favorite little auto parts store closed. Sometimes I drive to Ernie's, which is the best around here, but NAPA is closer. It's probably been 4 years since I swapped it, & I don't really remember. I can't remember the last time I was in an Auto Zone either.where did you get the MLSP from autozone?
I saw that, & that's where the question about stangmata's different description comes into play. I don't know if he knows something that we don't, or if it's a typo.Diagnostic Trouble Code (DTC) 634 indicate the Transmission Range (TR) sensor is out of Self-Test range when the gear selector is in "PARK".
DTCs 522 and 654 indicate the gear selector was not in Park during Self-Test.
Possible causes:
•Misadjusted linkage.
•Open or short in harness circuits.
•Damaged TR sensor.
•Damaged Powertrain Control Module (PCM) .
:beer, oh no i didnt take it offensively, i was just showing you and everybody what ''ALL-DATA diy'' said about those DTC's, compared to what you said another guy showed for them. you just said you werent sure if he was right, so i was just posting those DTC's so you could compare them.I usually buy those parts at the local NAPA, ever since my favorite little auto parts store closed. Sometimes I drive to Ernie's, which is the best around here, but NAPA is closer. It's probably been 4 years since I swapped it, & I don't really remember. I can't remember the last time I was in an Auto Zone either.
I normally won't say anything in a thread where I really don't understand the issue. He seemed lost & to be looking for any possibility when he said "If anyone has any other suggestions feel free to let them fly", so I threw in what I had seen that seemed to include different info than what you guys were already covering. I meant no offense, & was not trying to say that your info was off base.
im glad you solved the problem, happy wheeling.Well. It came to pass the the Ford powers that be see me fit to fix my Bronc. After countless hours of having my face in my Chiltons it turned out to be the ECM. The old saying "just cause' its new doesn't mean its good!" has came to bite me in the [email protected]@!! I should have tried it 5 months ago. This site as well as Google has provided me everything I need to know to fix my own rig. As far as tranny threads go this is another one solved. To every noob reading this thread, please use common sense and read directions. Always ask for help after you have taken all the right steps to fix your problem. Im by no means an expert. Thanks to all for their advice. Although I used to be a GM man, I LOVE MY BRONCO!!!!!!!!
