‘95 Bronco XLT 5.0 E4OD, MAF——‘95 F150 XL 4.9 M5OD 4x4, SD
Alright fellas hopefully this is my last thread for this issue. I created others for this same issue but the potential culprits in question for those threads have been ruled out and instead of dragging it on even more I just started another for ease of access. Hopefully that’s okay...
Okay so I have a stalling issue with my 95 E4od. The truck has been essentially unused for over 4yrs because of this. I have come to realize I had multiple issues I’m slowly getting them resolved. Also noteworthy that because it has been unused for so long some of these have probably occurred just recently while trying to make some more progress on it...
First was a new ecm. Got a reman and it seems to be doing just fine. Old one was toast. Next I replaced ICM and PIP after the new ecm gave code 211. Got it re-timed to 12*btc Now we’re running again and back to problem solving.
I still have a stalling condition once the truck warms up. Torque converter is locking up for unknown reason. I have ruled out the ecm both by replacing it and also by cutting the TCC line P/Y. Pin 53. It still stalls. It will do fine in all gears when cold. When it gets warm so far it seems to be okay with D most of the time. I’ve had it come and go on me. R will outright stall it and 1 and 2 will bog it down bad until I shift out of it. P and N are normal.
I tested the harness for voltage being sent by pcm thru pin 53 just a bit ago. It measured 1.8+/-v in all gears so I believe that is passing. Cut the line like I said and it’s still locking the TC. Which it should not be if I understand correctly. I noticed that the pan and transmission body were unusually warm/borderline hot and all i had done is yard driving and idling for like maybe 30 min. That didn’t seem right...
Any suggestions on how to proceed are much welcomed. Should I look at a new solenoid pack or am I misunderstanding something by coming to this diagnosis?
Thanks! -Breeze
Thanks! -Breeze
