yuo,
Have it scanned for Codes for Free at a parts store; ensure that NO Matter What they may say, that bother Key-On, Engine Off AND w/engine @ norm op temp that the Key-On, Engine RUNNING tests are done.
Post Any Code(s) found here by
KOEO
and
KOER
Possible MLPS Codes are;
DTC 624, 625, P1746, P1747 The Electronic Pressure Control solenoid is a variable force solenoid. The variable-force type solenoid is an electro-hydraulic actuator combining a solenoid and a regulating valve. It supplies electronic pressure control which regulates transmission line pressure and line modulator pressure. This is done by producing resisting forces to the main regulator and the line modulator circuits. These two pressures control clutch application pressures. Failed off — maximum electronic pressure control pressure, harsh engagements and shifts. May flash transmission control indicator lamp. CAUTION: The electronic pressure control pressure output from the variable force solenoid is NOT adjustable. Any modification to the electronic pressure control solenoid will affect the transmission warranty. (*Output circuit check, generated only by electrical condition.) Possible causes, Damaged harness connector. Damaged EPC solenoid. Damaged MLP sensor. Intermittent harness continuity. Damaged PCM connector pins. Pin Point testing; READ MUCH MORE @
http://www.fullsizebronco.com/forum/showthread.php?p=2452835
btw; Ford likes to confuse us by ref to the MLPS as da Transmission Range (TR) Sensor
P1705 Transmission Range (TR) Sensor Transmission Range (TR) Sensor not in park. On-Board Diagnostics not run in park. � Rerun On-Board Diagnostics in park
P0705 Transmission Range (TR) Sensor Transmission Range (TR) Sensor out of range. Indicated voltage drop across Transmission Range (TR) Sensor exceeds limits established for each position. Harsh engagements, firm shift feel. May flash TCIL
P0707 Transmission Range (TR) Sensor Transmission Range (TR) Sensor circuit below minimum voltage. Transmission Range (TR) Sensor circuit or powertrain control module shorted or grounded. Increase in electronic pressure control pressure.
P0708 Transmission Range (TR) Sensor Transmission Range (TR) Sensor circuit above maximum voltage. Transmission Range (TR) Sensor, circuit or powertrain control module indicates open. Increase in electronic pressure control pressure
P0783a Shift Solenoid 1, Shift Solenoid 2 or Internal Transmission Components 3-4 shift error. Engine rpm drop not detected when 3-4 shift was commanded by powertrain control module. Improper gear selection depending on failure mode and transmission range selector lever position. Refer to Shift Solenoid Operation Chart. Shift errors may also be due to other internal transmission concerns such as stuck valves or damaged friction material. May flash transmission control indicator lamp.
