I dont recall the size, but I believe the temp sender just threaded right in with mine. Its been a lot of years, but i dont remember needing any adapters.
From what I hear it is a dead end channel for a pressure test. So not much fluid flow passes by there. So basically measuring tranny housing temp.Out of curiosity, why isnt that the best (or equally the best) place to put the tranny temp sender? Its were I installed mine becasue I wanted to know the actual temp of the tranny. Seemed to work... I was hittin 210 prior to my cooler/filter install and am hittin around 170 after.....
Ideally you want the transmission to operate at normal engine temps you want to run through the extra cooler first then your radiator cooler. It keeps the engine temps down and the transmission closer to normal engine tempsHmmmm... interesting. That makes me want to put another gauge in the line and see the difference. It makes sense what you are saying, dont get me wrong. I think it would be worthy to test it though and see what the difference in temp is. It would help establish the most effective place to put the sender so ppl doing the filter/cooler install would not have to wonder or guess.... maybe I will pick up a cheap gauge in the next few weeks and give that a try....
Also, the dual tranny cooler set up makes a HUGE difference. Even on the trail in 90 degree weather on HOT rocks... my tranny never went over 180... can running a tranny to cold do damage?? (sorry for the hijack). Hoping this is info we can both (all) use.
My thoughts exactly..... my goal is to know how hot my transimssion (and fluid) are getting. That is where the damage could occur. If the temp of the tranny is dangerously high, I dont care if there is a cooler or not.... something is wrong and thats what I want to know. When I did my tranny fluid change, I could see where the sensor is located in the transmission. It looks like a pretty good spot to me.... the pressure port location is not in the pan, it is in the tranny housing, pretty high up on the tranny comparatively. I would think that the transmission itself would be the optimum place for the sensor, with the output being the second most desirable (with it mounted very close to the tranny) and the cooler return being the third.... I have left mine in that pressure port because from what I can tell with the visual inspection of the opened up tranny, thats about the best place for it....I think you need to think about what you are saying again. We need to see the max temp of the fluid to know whether or not it is breaking down, who cares how cool it gets, is its at 250 degrees before the cooler and then it comes out of the cooler at lets just say (not realistically) 140 degrees, would you ever know if you have smoked the fluid or not?
