well Im a newbie when it comes to FSB's i just upgraded from a bronco 2 but anyways my 1994 Bronco 351W with an e40d every once in a while will shift really hard and at a higher rpm than usual most of the time 1st-2nd, but my speedo doesn't behave erratically, my odometer works just fine, u-joints are new, transmission fluid is at the correct level and the transmission was fully rebuilt at a local shop by a guy who specializes in e4od's about 40k miles ago, so from my understanding this leaves a sensor to blame? could it be the the speed sensor in the rear differential causing this weird behavior? or something else? all help is greatly appreciated :banghead
