Swapped my parts truck E4OD into the Bronco after my pump seal blew out on my original trans. New trans seemed to be working fine around town, but my shift indicator was way off and I could get it down into 1st gear. Adjusted the MLPS this past weekend but it didn't seem to make any difference. Drove the truck down to work today, about 100 miles, and it seemed to run fine.
Went out at lunch today and when I came back it clunked into reverse and slipped backing up. Had to rev the engine to get it to move and it was clearly popping in and out of gear. After work, I tried reverse upon startup and it was fine, but after a 30 min drive it was hesitating again. Also seemed to slip a little in OD when accelerating from a stop.
When I got home I adjusted the shift indicator after looking up on here how to do it, saved again by FSB! Didn't realize how easy that would be! :doh0715:
Then I adjusted the MLPS back to the original position from where I moved it this past weekend and took the truck for a cruise. Again, was fine at first and then slipped once it was warm. Is it possible that the shift cable needs to be adjusted? I looked up the procedure this weekend and didn't understand the following instruction:
4. Pull down the lock tab on the shift cable body.
What lock tab? I've been under the truck multiple times and have no idea where the lock tab is? Found this diagram searching and still don't get it.
http://www.supermotors.net/vehicles/registry/media/434182
Can someone shed some light? Is it even possible that an out of adjustment cable would cause the trans to slip badly in reverse? I searched, but all I found were the instructions in the link below from the Chiltons manual, but there's no pics.
http://www.fullsizebronco.com/forum/showthread.php?t=98564&highlight=e4od+cable
Thanks!
Thanks!
