1991 Bronco 5.0. I'm testing my shift solenoid pack by checking resistance across the pins. I'm supposed to have 20-30 ohms of resistance at the solenoids but only have 18. To me this is a failed test but none of the testing instructions I've seen tell what it means if the results fall outside of that range, even by a few ohms. Has anyone else performed this test with similar results? Solenoids 1,2, TCC, and Coast Clutch all had 18.6 ohms. The EPC showed 4.4 which is within the acceptable range. Fluid Temp sensor resistance was around 78k which is acceptable based on the current temperature. Here is the diagram I used for testing.
