hey yall, i think my tranny is about to take a shit so im thinking about swapping the e4od to a c6 or aod. what kind of problems would i run into with the computer for this? ive got a 91 351.
thanks yall
aka: kemicalburns
i would swap in a zf, same amount of work and you dont loose the strength or Overdrive.
but to answer your question, the computer will throw a code but otherwise not affect how the engine performs. you can also find a motor/C6 ecu combo that fits what you plan to run and not get the computer throwing codes.
thanks man, how hard would the rest of the swap be with the zf? like the pedals, clutch slave, ect
is the c6 bompletly bolt-in? any adapters or anything like that?
aka: kemicalburns
do a seach for zf swap. its been done a bunch recently with everything you need. its no more complicated then going to a C6 thats for sure.
I swaped my E4OD out for a C6 If I could do it over again I would find a parts truck cause your going to need a lot of parts to swap in the C6 such as drive shafts cross member linkage harnesses which can rack up the cost of the swap.
