1 - 8 of 8 Posts
title says it all, my truck was running fine, then i went to re start it 5 mins later and it wont shift outta park. the shifter just wont move. any ideas, im sure its the trans linkage but really i've got nothing.
all of above;
fyi;
"...Shift Lever Stuck in Park (pic is gone); "...These (and many other) vehicles are equipped with a Brake/Shifter interlock for safety. This system requires the driver to hold the brake depressed before the shift lever can be moved from the Park position. There is an actuator (solenoid) on the left side of the steering column under the dash that disengages the shifter lock when the brake is depressed. In the event this system malfunctions, the shift lever may be stuck in the Park position. One cause of this complaint may be due to a faulty brake switch circuit. If you experience this complaint always check for blown fuses and brake light switch operation before proceeding with other work..."
Source: by ATC-Distribution Group Inc.
1 - 8 of 8 Posts
